| | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50819 10/03/2005 7:46 PM | Joined: Jan 2004 Posts: 43 Junior Member | | Junior Member Joined: Jan 2004 Posts: 43 | Yes, your carb may need a rebuild. You might want to check to see if your idle mixture screw has any effect and an intake leak is definitely a possibility. Make sure carb is tight on intake and intake is tight to head. Bill. | | |
