Thanks for the input Denny. I am looking for something that I could mount under the dash next to the radio. I may try to pad down the output of the first transmitter to a few micro volts and use an antenna switch to put it straight into the antenna input. The other option would be to modify the radio with a switch to go between the detector output and the Ipod output through a capacitor.
