0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I have seen the following missed and a small oil leak results. In front of the fuel pump on the front block face there is a bolt hole for holding the fuel pump rod when replacing the pump. It normally holds a short bolt to keep oil from leaking out the hole. When you remove the fuel pump you use one of its longer bolts by removing the short bolt and screwing in the long one. When the long bolt is removed and reinstalled in the fuel pump the short bolt is sometimes forgotten.
