| | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy barndoor and guys, it could be a 235, but it is a low pressure babbitt pounder engine for sure, as evidenced by the little plate on the left side of the block, just above the pan, about half way down the engine. It could have been converted to insert rods. But you have to change the crank to get oil to them, hope that helps. | | |
