| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Not necessarily, but the pipes off the manifold flanges don't need to be very big or you'll mess up the back pressure and possibly draw cold air back to the exhaust valves as the pressure pulses cycle. A split manifold only has half the pulse frequency in each pipe as a single exhaust, and the pulses occur every 240 degrees of crankshaft rotation. That's what gives a split manifold six the characteristic "BRAAAAAPPPPP" sound, but it can also warp valves with cold air if the pipes are too big. Jerry
