12 members (Otto Skorzeny, greenie-reddy, KEVINSKI, Bill Hanlon, 1955 1 Series, klhansen, Ponchogl, cmayna, Peggy M, Gdads51, 2 invisible),
119
3
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I have a 3 leg stand that I use on the V-8's and I also have made out riggers for the stand that can be bolted on the back section and the front section has a small 12" cross piece that can be bolted to it also. If I build another stand I will incorperate a slide out center leg with pins and 2 wheels 16" wide for extra safety. I had a simlar expericence with a Chevy 6 rolling over but was lucky I still had the engine hoist attached. That could of gotten messy too. My engine stand is built out of 21/2" sq. tubing 1/4" thick and the mounting bars are of keystock 5/8" sq. all bolts are grade 8. It's better to be safe than sorry. The Cheery picker I use is made out of 3" sq. 3/8" thick tubing all the away around and I have picked up some heavy engines and other things with it. It comes apart but does not fold up. This is my friends picker he used a 12 ton jack on it. That is a little overkill but it works. 62Blue. Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
