Anyone know where I can get head bolts for my 54 235, specifically head bolt studs. Im working on putting a power steering pump on my 54 235 and need to change out the first two head bolts on the driver side of the head to studs. The alternator is being moved up high and my plan is to have the bracket bolt up using studs.
Thanks
My last resort is to weld a bolt on top of the head bolt, but Im hoping that isn't going to be needed.
