| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | 47ranchtruck is right.The fuel filter you are mentioning was an option when your stovebolt was new. The fuel filter is on the fuel pump (glass sediment type) the option was one mounted at the carb __________________________________________________ 37 Chevy 1/2 Ton
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
