9 members (Gdads51, rfs56trk, FAST55, HandyAndy, 3B, Shade Baby, Hanks custodian, Wally / Montana, Otto Skorzeny),
51
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,038 Posts1,055,584 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | sounds like a 216 intake. studs should be 2 15/16 for the 235 and 2 11/16 for the 216. if you can find a part # cast on the intake post it and someone may be able to give you a positive id. you can also go to http://chevy.oldcarmanualproject.com/ and find references to the part # yourself. good luck big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
