Originally Posted by Bernd
Hi Stuart,
thanks for the info.
Do you experiance Bump steer?? How much different is the ride with the anti rollbar?
Thanks
Bernd
Bernd, I don't have any noticeable bump steer on my truck, but the ride height is near stock at the front,so my drag link is parallel to the road when the truck is stationary. If your truck has been lowered you may need to crank the Pitman arm to get the drag link parallel to the road; this should make a big difference to the bump steer if your drag link runs steeply uphill or downhill now.
The anti rollbar (swaybar) has improved the cornering a lot, but doesn't seem to have affected the ride otherwise.
Originally Posted by rfs56trk
I'm fairly sure that they use the rotors and calipers from a mid 70's to early 80's 4X4. The brake pads should be the same for the 4X and regular 2 WD 1/2 ton trucks of that era.
Fred
Thanks Fred, along with lots of other useful parts, I picked up a set of 1975 C10 2WD pads at the NAPA store in Denver last week, they are the correct pads for my CPP 6 lug conversion.
Here's the NAPA part number if anyone else needs it.
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=TS&PartNumber=TS728A&Description=Brake+Pads+-+Front%2c+Organic+Tru-Stop
Thanks to all for your help. Stuart.
