Would like to put some steeper gears into my 52' AD. I'll be pulling everything off the frame for a total restore in the next couple of weeks. Would like to get rid of the torque tube and go to an open shaft along with a 3:55 rear end or? What would be the process/ suggestion for my 235 with 3-on-the-tree. Also, I've heard that when you go this route to an open shaft you have the option with a simple hardware change (called a "flip") to lower the frame a couple of inches???
Thanks ahead of time.
