Well, it's been difficult routing the lines to the M/C. I got a M/C with the ports on the outside frame side to avoid the Patrick's shift linkage on the saginaw. But the front port on the M/C is so close to the bracket that I think I neeed to drill a hole thru it to route the line from the front brakes. that should work.So new bends in the lines and a T and short line thru the new hole to the M/C. Then I'll be home free.
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
