Nice work Leonard! You know, you have about the cleanest 56 I know of. What did you do with everything off the firewall? You do really neat stuff - and it sounds great RRK --- What size motor is that??
Dale
thanks dale.
i bought my 57 already painted and motor and trans installed. the firewall was the way it is now when i bought it.
i did clean the engine up a bit, with new wires and valve covers.
i lowered it, putting a new front axle in, power front disc brake conversion, and a few other things.
the engine is a 1980 350 4 bolt out of a 1/2 ton truck. trans and rear from the same year truck.
thanks again..
leonard
