I called a friend of mine that used to do a lot of hydraulic work. He said that you fill it through that hole in the big cyl.
With it down you can fill it all the way. If it is up you don't want to get too much in or you can guess what happens when you lower it. Put in enough so it will raise all the way.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
