2 members (RayF, MNSmith),
154
Mod | | | Forums66 Topics128,284 Posts1,058,528 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49136 08/17/2005 1:40 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | The detent in the rail for second is either worn ,,or the spring isnt holding it in... or also could be the shift lever ball is worn where it goes into the fork...its probably the detent tho... those 420's thats the first thing to usually go is second gear...typically its the collar and gear thats worn or tapered...rather than the fork not going all the way in... all a sychronizer will do is stop the gear from spinning or slow it down to allow it to mesh into gear without grinding....the sychronizer usually wont cause it to jump outta gear or not allow it to go into gear all the way.....its a gear brake is all it is.... as in puttin it in low where it doesnt have a synchronizer it will grind a little sometimes.....same with reverse...
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
