0 members (),
59
2
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You'll find a lot of people have dealt with this problem and taken various routes to solve it.
Your 3/4-ton with a 1-ton rear could be a 3/4-ton that someone swapped a 1-ton rear under... But the standard rear under your truck would be an Eaton with 4.57 gears, and the only option GM offered was an Eaton with 5.14 gears. The 5.14 gears are the only ones GM offered in the 1-tons of the era.
So I suspect that is what is meant by it has a 1-ton rear.
The easiest solution to your problem is to replace just the differential portion of your existing rear with one from a newer truck that has 4.11 gears. Unfortunately those are hard to find.
I've replaced the 5.14 geared rear under my 1-ton with a much later GM 14-bolt that has 3.42 gears. I'm also planning to run a Cadillac 500 so I'm not worried about the gear ratio, while in your case you need to make sure you chosen gears that will match your motor and transmission to your intended loads. My gears might not work if you want to load the truck heavy.
Do some searching using 8-lug or Eaton or some similar terms and you'll find much more information.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
