| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48893 08/11/2005 2:38 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "For steel castings etc. where the mating surfaces do not flex, I would guess that a more spongy gasket might be best" like a head gasket? ... or a thermostat housing gasket? ... or a trans side cover gasket?
gasket material depends on the "material" being contained as much as the mating surfaces - pressure, oil, grease, water, air nowadays many gaskets can be replaced altogether w/ sealer, or 'liquid gasket maker'
Bill | | |
