8 members (Rustnut, Otto Skorzeny, Gib70, Bisbee, Southerntruck, Gdads51, greenie-reddy, 1 invisible),
97
3
Mod | | | Forums66 Topics128,079 Posts1,056,300 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48596 08/09/2005 5:35 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Patrick's has a set of brackets that puts the a/c compressor where the generator used to be and the alternator above the intake on the same side. The compressor has a two groove pulley and is hooked up the crank and water pump with a smaller belt to just the alternator. Set of brackets is about $100, maybe less.
I'd like to add p/s in addition to a/c and am going to drill the old pully off the harmonic balancer, thread the holes and bolt in a two belt pulley to be able to run the p/s on the passanger side of the engine. I think I found a aftermarket bracket that'll work but am going to try looking at the brackets on other l-6's in the boneyard and maybe have my block/head drilled and threaded to use one of those, if there is meat in the right places that could be drilled/threaded.
'51 Chevy 1/2 ton w/'62 261, HEI, offy, fentons, dual carter/webbers, t-5 & 12 bolt posi
