Everything now clean and tight ran the truck for a few minutes and the voltage seemed to hold steady at just over twelve, not as much as it was putting out on a regular basis before(14-15) it was clean. With the heater fan running plus the lights on it drops to 11.25 -11.5 is that about right? Have concerns about not enough power now when i turn on amp and sound system. The truck is stock except for the engine rebuild is it maybe just time to address the 50 year old wiring.
Ce messam do menmain?
