cab to frame
cab to bed
engine to frame
i run a ...
radiator frame to frame
inner fender to frame. because i have an electrical relay panel mounted on the drivers inner fender. i also run a pusher fan so that's why the rad frame to main frame.
all this in addition to the bolts that may work holding everything together.
every frame, cable and ground bolt is coated w/ NCP-2, electrical grease.
http://www.batteriesareus.com/index.php?main_page=product_info&products_id=9685
Jim & Caroline
The highway is for gamblers, better use your good sense."
Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe
Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
