For the brake drum removal did you back off the adjusters all the way before tying to remove the drum? Also make sure the emergency brake cable isn't actuated at all, ie unhook cable and make sure it moves freely.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
