Yes the intention is for the Big Bolt to Tow the Little Bolt. I have posted a picture of the way I think they will look when the project is done in the 1953 4400 BIG TRUCK link on the first post.
This is also a list of the things done to the 53 since it came to my place.
New tires mounted on the original Widow Maker Wheels
Total rebuild of the 1954 GMC 235 motor with Mallory electronic ignition
Rewire from fire wall forward
Air bags and shocks on all 4 corners
Total front end rebuild including spindles, tie rods, bearings, king pins, and brakes
Moved battery to under hood and converted to 12 volts with alternator
New clutch, throw out bearing and emergency brake pads
All new rubber for cab and doors, new head liner and window whiskers
Rebuilt inside cab and covered with diamond plate
Lokar throttle linkage and pedal
Fabricated vinyl boot covers for shifter and emergency brake handle
Converted starter to dash button and solenoid start
Air horns with compressor and tank which also services the suspension air bags
