1 members (Eileen),
271
2
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 15 New Guy | | New Guy Joined: Nov 2008 Posts: 15 | Hey all,
Working on the doors on the dump truck. I have new felt window channels to install. The "run clips" I got from american classic are different from the flat originals:
http://hubcap.clemson.edu/~willys/run_clips.jpg
I assume that I drill holes in the door for these to pop into. What's the trick? Affix them to the doors then to the channels? Or, how do you get the holes in the right place?
Also, I have a new wiper seal to install as well ... danged if I can get it to slide in ... is it possible to push in one side, them coax the other in? Silicone lube?
Thanks for any insights ...
-Dan
1950 Chevy 1.5 ton dump | | |
