A wider gap helps drivability a little. Its like a bigger match. They claim a smoother idle. I wouldn't go beyond .045 though on a Chev. When HEI first came out they were running very wide gaps, like .060-.080. They had some problems with starting in damp weather, especially Chev. so they lowered it to .045. The heat range is the path the insulator takes to transfer heat to the shell. The insulator should run white to light grey. If it carbons up it or gets a red varnish it is too cold. If it blisters & erodes the electrodes it is too hot.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
