1 members (Hotrod Lincoln),
49
6
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | With your HEI ignition you should run a wider gap than what the tune-up specs called for. The HEI produces a hotter spark which likes a wider gap for better ignition. Going from memory here but I think around .045" is about right. Set it and forget it. It's always the same regardless of how you intend to drive the truck. You always have to check the gap when installing plugs since the gap is easily changed by simply mishandling the box during shipping.
