I have a problem - Does anyone know the Best way to remove Critter Smells from the cab of a truck . The last owner let his cat keep down the mice problem by leaving the floorboard battery box door off so it could come and go . The problem is it "went" inside the cab and did not control the mice very well for there is also a mice smell . Please any sujestions will be helpful . You just can't survive in the cab for long without a personal air tank even with the windows down . Thanks ED H
