| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Have somebody test the radiator cap. A weak pressure relief spring, and/or a bad gasket will allow it to puke coolant after shutdown. A good-condition cap a couple of pounds higher rating might help IF you've got a tubular radiator that will handle the extra pressure. Don't overstress a honeycomb radiator with a too-high pressure cap.
A recovery system will allow it to recycle the coolant, if you don't mind going non-stock. Jerry
