| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | This http://www.alexander-mills.co.uk/sip/compressors/workshop2.jpgis what I use to run the bigger 110 lb pressure blaster with proper grade coarse garnet and have found that it is easier to clean residue from parts and can be re-used several times unlike soda blast media. Soda is more suited to surface finishing than heavy duty stripping!
