| | | Forums66 Topics128,181 Posts1,057,184 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That is true, don't tow in overdrive. When the early 700s are run in overdrive, the line pressure actually drops. Towing will cause the clutches to slip since there is less pressure to hold them locked. The later 4L60E trans with the Tow/Haul switch actually regulates the pressure electronically, and raises the line pressure for towing in overdrive. One more note about the 700R4 over the TH400, the 700 has a deeper first gear, which is better for takeoff.
Bill Burmeister | | | |
Entire Thread
Transmission swap- 4 spd out, 3 spd auto in, HELP!
| oem4me | 11/30/2008 5:23 AM |
Re: Transmission swap- 4 spd out, 3 spd auto in, HELP!
| LONGBOX55 | 11/30/2008 5:30 AM |
| 3B | 11/30/2008 5:33 AM |
| Lonnie Gallaher | 11/30/2008 5:40 AM |
| oem4me | 11/30/2008 7:08 AM |
| Wrenchbender Ret. | 11/30/2008 4:03 PM |
| oem4me | 11/30/2008 4:50 PM |
| Chief Full aBull | 11/30/2008 11:27 PM |
| Wrenchbender Ret. | 12/01/2008 10:30 PM |
| Scott Danforth | 12/02/2008 12:29 AM |
| 6tvette | 12/02/2008 1:45 AM |
| LONGBOX55 | 12/02/2008 4:54 AM |
| oem4me | 12/02/2008 8:23 PM |
| Wrenchbender Ret. | 12/02/2008 10:32 PM | |
