isolate......
look at the brake rod, pedal arm & see if you're pulling a wire and shorting it??
pull fuses and see what circuit is involved. when you pull that fuse and nothing happens at least you found those sets of wires involved. see you're wire diagram.
good luck
Jim & Caroline
The highway is for gamblers, better use your good sense."
Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe
Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
