8 members (55shaker, 78buckshot, dt235sd, baldeagle, rick46ia, Stovebolt48, Gdads51, 1 invisible),
163
Mod | | | Forums66 Topics128,268 Posts1,058,379 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | crowsgmc,You need to know if you have the early 1955 261 or the late 1955 261. If I remember right,the oil pans are different.The early oil pan flanges curves around to straight line(the surface where the gasket is). The later 1955 pan one side curves around and jogs at an angle before it goes straight(the surface where the gasket is).I believe if you got the correct year of 235,it will match the 261 oil pan. Lets see what the experts have to say.
Correct me if i'm wrong . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
