| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47630 07/13/2005 4:12 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | OK I'll give this a shot. The shoes on Huck brakes adjust seperatly, so there are two adjusters on each wheel. Pull the rubber covers off the adjuster holes on the backing plate and youll see the adjusting wheels. Now take a screw driver and turn one of the wheels clockwise (looking at the end of the wheel cylinder) and turn the wheel. Keep adjusting until you feel the shoe start to drag, then back off 4 slots on the adjuster. Repeat this for all the adjusters (2 for each wheel). Typically I'll drive it a little then jack up the truck and give the wheels a spin to see if the shoes are dragging. If not you are good to go. Hope this helps George | | |
