1 members (baldeagle),
40
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | I have some time tomorrow and want to pull the trans on my 36, do I have to remove the whole rear axle and torque tube to get the trans out. This is a one and a half ton with a 4 speed and there is a welded plate under the front drive shaft section that is a 12" channel with a drive shaft cut out. I know the front u-joint should come off but, I can't get the bell to slide back far enough to get to it. I removed the rear bell and I can move it a bit more but no joy, will freeing the center bearing buy me anything. I can't move the drive shaft down because of this plate and the channels are notched for the drive shaft. The only way I could move the forward shaft would be up and then to the sides.
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck 1970 Mercedes 280SE 3.5 coupe 1987 Mercedes 560SEC supercharged 1989 Mercedes 300CE 5.0 M119
Entire Thread
Pulling a torque tube trans
| Steve Lemberg | 07/11/2002 4:36 AM | |
