http://www.dynatrac.com/ and or some other companies that regularly and professionally build axles from scratch should be able to narrow an axle for you, and re-spline or provide new axle shafts.
Won't be cheap, and at that point you may be better off having a new axle made to suit, from the same folks.
also try http://www.solidaxle.com/
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
