| | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Yes, at the dealer I work for we have a device that checks the guage using veriable resistence. You hook up the device to ground and to the wire at the sending unit and turn the knob. This causes a resistence that changes as you turn the knob. When the knob is at its lowest setting the guage reads cold, middle setting reads normal, and highest setting reads hot. So with that in mind ground the wire st the sending unit (with the key on) and see if the guage moves to hot. Ya know I wrote all this and it occured to me that you may have a mechanical guage. If so, boil a cup of water in the microwave drop in a thermomature when the temp gets down to 190 drop the sending unit bulb into the water and watch the guage.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
