I believe the outboard ends of the rocker shafts are sealed with a small plug. With the entire assembly removed, it's still tough to get the gunk out of the bore of these shafts with the plugs in.
They can be driven out, the shaft interior cleaned 100% and then tapped in again or new ones installed. I think they're a common Dorman item but don't quote me on that.
Stuart
