| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I was going to put a 292 into my 3800, but after getting the 235 running, I probably made a bad decision and got rid of the 292.
The 292 is actually very close to the same size as the 235 because it uses thin wall castings. The one big difference between the 292 and most other Chevy 6s is that the 292 has staggered motor mounts. The one on the passenger's side is farther forward that the one on the driver's side. Not such a big deal since you will probably be putting in new motor mounts anyway. (To get the engine to fit correctly.)
I think that the 292 is a good swap since it doesn't the weaknesses of the 230/250, and it has the same torque rating as a 350.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
