| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The beehive oil filter is mounted on the manifold side of Chevrolet 216/235/261 engines. My guess is that the engine at the Patrick's link (above) is a GMC straight-six (the oil filter on those engines is normally on the distributor side of the engine).
davidn,
Is it possible to mount a standard by-pass oil filter on the Clifford intake? If yes, the stock adapter from Patrick's should work. Note: call in your order and ask about the bracket you want - their old catalog had the parts numbers backwards.
Tim
