12 members (gswbbc, Gdads51, Scott, frogfarmer, panel fan, FAST55, JW51, Wayne67vert, Lightholder's Dad, 48jim1ton, tclederman, 1 invisible),
70
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | My hobart 140 has 4 heat settings. On thin stuff I start out with 2 the heat and 30 on the wire speed. I practice on some junk similar to what I am welding to get the wire speed right. Something like floor panels I start out with 3/30 but If I burn holes I turn the heat down to 2. I think most machines come with Electrode Negative which is for flux core. If you are going to use shielding gas, you need electrode positive. I have seen people that didn't reverse their polarity to use mig. I just looked at the link to the welder you have. It looks like flux core only. I just looked at my Hobart book which surprises me that I still have. They recommend a heat gauge setting of 1 which is the lowest and wire speed of 30 on 18 gauge. They do not recommend welding anything lighter than 18 gauge with flux. This is the first time I have ever looked at charts, but looks to me that you may be trying to weld something thinner than what your machine was designed for.
