| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | remove the winndow garnish. remove the door panel. reach in and find bolt that holds the vent channel and remove. remove the 2or 3 screws on the front part of the bracket holding the wing in place on the forward side of the door. remove channel with vent as a unit and set aside. pull glass out of channel and remove glass. if i remember i had to cock the glass as i pulled it out of the channel. i did two last winter but that was a long time ago. | | |
