Brad;
I installed a 10 point fuse box under my dash near the steering column but up high enough so one can't see it. I took the switched hot from the ignition switch and ran it to one side of the fuse block and then jumpered the hot to the accessories that I didn't want to draw voltage until the ignition switch was turned on. The other items that I wanted to be able to turn on without the switch being on were fed with 12v hot all the time. Pretty easy to do. Good luck.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
