You can put fittings where the plugs are and loop a heater hose between the two. When you get ready to install a heater, you will be 1/4 of the way done
- - By the way,,, WELCOME TO THE STOVEBOLT
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
