| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Just use a 6-volt Ford starter relay, and wire the energize lead to a hidden push button under the dash. When you push the button, the relay closes and puts battery power to the top terminal on the stomp starter switch. Those old relays were used through the 40's and 50's until 1955. There's one small terminal that is grounded by the starter button on the older ones. Newer models needed battery voltage from the "start" position of the ignition switch.
