| | | Forums66 Topics128,260 Posts1,058,322 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46334 06/17/2005 3:49 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've used MolySlip in trans/rear gears before, but if you've got bad parts lube won't fix them, especially worn syncros - and 'gear grinding' beyond worn syncros is the driver and/or clutch!
Bill | | |
