| | | Forums66 Topics128,131 Posts1,056,373 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Does it have the 4 bolt side cover? If it has the long tail shaft (22" overall) it could be from a 55-61 truck or 55-57 car. If it has the short tail shaft (17" overall) it could be from a 62-67 truck or 58-67 car. There is a date code on the tail housing along with some casting numbers. A date code like: A 15 0 would be Jan 15, 1960. There are some minor differences between car and truck transmissions such as the side cover and the lower mounting holes. 6 cyl and V-8 transmissions were the same in that era. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
