| | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | I don't think the rope and the rubber seal are interchangeable. You get both seals in the gasket set so you can use whichever one fits the rear main cap and the block.
It's not uncommon to have a little drag on the crank with a newly-installed rope seal. It "wears-in" very quickly, forming itself into a leakproof fit to the crankshaft. It wouldn't surprise me if you get a big leak from using a rubber seal where a rope should be. Jerry
