Will need to run 1) 12 volt, and 1) tach wire to my distributor. Unfortunetly, I did not think to take a look at, much less tie into my distributor before i put it in. :mad: Now, I only have about one or two inches between it and the firewall. As you can see, I no longer have much space to work with. Am I in need of a special connector, or will it be something like This? If it is something like that, what size will it need to be? Thanks for any help.
Give me my Truck, or...my truck daamit! Cause i aint leavin without it!
http://picasaweb.google.com/jadefalcon1218/MyK10
