| | | Forums66 Topics128,193 Posts1,057,246 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | The Chevy Dealer in your Town can tell you exactly what year it is by the number on the front milled boss. I have gotten info with the RPO. numbers several times. By getting the numbers off the back of the block and the numbers off the heads you can see if they are a match set of heads. The numbers are cast into the block and heads. Like Seetz said they have books out on all cast numbers now. The book I have with the RPO. codes in it says it is a 1967 283 cu. 210 HP. 2BBL.carb with a Power Glide out of a Camaro. This would mean that was the first produced Camaro year. That is the only MJ. Code in the book. The book I have is from coverage dates 1955 to 1996 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
