8 members (Donf, Goach2, Otto Skorzeny, cmayna, Joe H, Wally / Montana, Gdads51, 1 invisible),
89
0
Mod | | | Forums66 Topics128,118 Posts1,056,307 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The headlight bezels or chrome rings are hooked in at the top and secured by a single screw at the bottom. There is a set of clips that goes inside the headlight ring. They serve to hold the rubber gasket in place and also the top clip has a tang that slides into a slot in the top of the headlight pot.
It also sounds like your hood hinges are worn out. Look at the pivot holes in the hinge. If they are distorted and enlarged then they are worn out. | | |
