Thank you for the replies. It sounds like you've both found the parts at regular parts stores, but I can't imagine stores here in LA stocking these parts-everyone here drives japanese cars.
Fred T, my diff IS a 10 bolt, -does the redi-sleeve go on the trunion or the pinion shaft? Also, is this part readily available, and does it come in a standard diameter?
